Red Expert Updated and fully compatible 1.8.x
VresT Offline
LwG!
Liczba postów: 2,361
Reputacja: 148
Podziękował: 1813
Podziękowano mu 3186 raz(y)
I’ve done major modifications to the RED Expert 2 mod (which is no longer developed since 1.3.x patch) so now it properly renders the sky and light flares at night on the latest patches. This mod also adresses the AI lights distance and brightness!
RED is a mod which renders a beautiful sky and cloud formations, also adds vegetation and HD road surfaces. To load the HD textures, add the following line to the config file located on drive C (where your mods are):
uset g_texture_hd_enabled “1″
Is compatible with Promods and TSM map mods.
Recommendation disable color correction setting in the game graphics menu.
Original credits go to – Environment Simulating Studio© for Real Environment Dimension
- AlterEgos for Heavy modifications (for latest patches), tweaks and additions (WIP)
UPDATE 21/09/2013 Corrected faulty textures.
UPDATE 27/09/2013 MUCH Improved light flares, truck and AI headlights, a brighter Night environment and moon.
UPDATE 28/09/2013 Slight adjustment of light flares.
UPDATE 29/09/2013 Corrected night time skybox textures.
UPDATE 01/10/2013 Optimized, corrected textures, light flares (now warmer and specular), added and tweaked things.
UPDATE 02/10/2013 Added and modified some models, removed (potential) conflicts prone traffic data with other mods and left only the necessary things needed for a good experience.
UPDATE 04/10/2013 Further tweaks
UPDATE 06/10/2013 Added more HD textures, “fined up” some textures.
UPDATE 07/10/2013 Roadworks and other “potholes” filling.
UPDATE 10/10/2013 Redone light flares, tweaked the sky, redone some textures. You can use HDR now without worrying about the “bleach” effect.
UPDATE 13/10/2013 I have added many more textures, added sunshaft effect as many have requested it (but kept it real, if you want magical sunsets and what not, go play Skyrim), tweaked the overall HDR and light effects, the night time environmental and AI light flares now finally are close to perfection.
UPDATE 18/10/2013 Updated lots of textures, slightly reworked HDR.
UPDATE 23/10/2013 Improved color and contrast; slightly modified weather pattern; corrected some textures with missing alpha channel; other small improvements.
UPDATE 03/11/2013 Added textures, improved HDR, added my latest versions of the Awesome rain and True Ai lights in the package. Added and modified interface sounds, some environment sounds.
UPDATE 12/12/2013 This update contains the following changes: better cloud cover, the sky now has a deep blue color, improved sunset, once more improved light flares for environment and AI. Also, this update is fixing the map zoom error in some map mods.
Author: AlterEgos
Tłumacz:
Zrobiłem główne modyfikacje RED Ekspert 2 mod ( który nie jest już rozwijany od 1.3.x plastra ), więc teraz to właściwie czyni niebo i światła flary w nocy na najnowszych poprawek . Ten mod adresy także AI odległość i jasność światła !
RED jestmod , który powoduje, piękne niebo i chmura formacji , dodaje również roślinność i nawierzchni HD . Aby załadować tekstury HD , należy dodać następujący wiersz do pliku konfiguracyjnego znajdującego się na dysku C (gdzie twoje mody są ) :
uset g_texture_hd_enabled "1"
Jest zgodny z Promods i TSM map modów .
Zalecenie wyłączyć ustawienie korekcji koloru w menu graficznym gry .
Oryginalne kredytów przejść do - Środowisko symulowanie Studio © Real Środowiska Wymiaru
- AlterEgos do dużych zmian ( do najnowszych poprawek ), poprawki i uzupełnienia ( WIP )
UPDATE 21/09/2013 Poprawione błędne faktury .
UPDATE 27/09/2013 dużo lepsze race świetlne, ciężarówka i reflektory AI ,jaśniejsze otoczenie noc i księżyc .
UPDATE 28/09/2013 Lekka korekta światła flar .
UPDATE 29/09/2013 Poprawione Skybox tekstur nocy.
UPDATE 01/10/2013 zoptymalizowane , poprawione tekstury , race świetlne ( teraz cieplejsze i lustrzane ) , dodano i manipulowane rzeczy .
UPDATE 10.02.2013 Dodano i zmodyfikowano kilka modeli , usunąć ( potencjalne ) konflikty podatnych danych o ruchu z innych modów i lewo tylko niezbędne rzeczy potrzebne do dobrego doświadczenia .
UPDATE 10.04.2013 Kolejne szczypie
UPDATE 10.06.2013 Dodano kilka tekstur HD , " ukarany grzywną w wysokości " kilka tekstur .
UPDATE 10.07.2013 drogowe i inne " dziury " do napełniania .
UPDATE 10.10.2013 race Redone lekkie , manipulowane niebo , odnowione kilka tekstur . Możesz użyć HDR teraz nie martwiąc się o "wybielanie " efektu .
UPDATE 13/10/2013 Dodałem wiele więcej tekstur , dodaje efekt sunshaft jak wiele osób o to ( ale trzymał go prawdziwym , jeśli chcesz magiczne zachody słońca , a co nie , idź grać w Skyrim ) , manipulowane ogólnej HDR i efekty świetlne , czas nocy i race świetlne środowiska AI wreszcie są bliskie doskonałości .
UPDATE 18/10/2013 Updated wiele tekstur , lekko przerobione HDR .
UPDATE 23/10/2013 Lepsza kolor i kontrast , nieco zmodyfikowany wzór pogoda sprostowanie niektórych tekstur z kanałem alfa ; brakującego innych drobnych usprawnień .
UPDATE 11.03.2013 Dodano tekstury , ulepszone HDR , dodaje moje najnowsze wersje Awesome deszczu i prawdziwego światła AI w opakowaniu. Dodane i zmodyfikowane dźwięki interfejsu , niektóre środowiska brzmi .
UPDATE 12.12.2013 Ta aktualizacja zawiera następujące zmiany : lepiej zachmurzenia ,niebo jest teraz głęboki kolor niebieski, ulepszony słońca, jeszcze raz
ulepszone flary świetlne dla środowiska naturalnego i AI. Ponadto, ta aktualizacja naprawia błąd powiększenia mapy w niektórych modów map .
Przed napisaniem posta zapoznaj się z regulaminem,bądź skonsultuj się z Administratorem lub Moderatorem, gdyż każdy post niewłaściwie napisany zagraża twojemu poziomowi ostrzeżeń.
(Ten post był ostatnio modyfikowany: 14/12/2013 07:02 PM przez Michal_Z_gno.)
14/12/2013 03:24 PM
 Podziękowań: Michal_Z_gno
Osesek Offline
Na papieża!
Liczba postów: 621
Reputacja: 50
Podziękował: 1110
Podziękowano mu 700 raz(y)
RE: Red Expert Updated and fully compatible 1.8.x
Jest jakiś spadek FPS?
[align/]Image
Nic, nie dodaje.. Nic nie usuwam.. Nic nie konwertuje!! Nie pisać do mnie w tych sprawach ani tutaj ani na GG bo mam dość! To, że raz wam coś zrobiłem nie znaczy, że będę to robił ciągle!
14/12/2013 03:56 PM
VresT Offline
LwG!
Reputacja: 148
Podziękował: 1813
Sprawdzę tak za 1 godz jak to chodzi ;P
14/12/2013 04:38 PM
Osesek Offline
Na papieża!
Liczba postów: 621
Reputacja: 50
Podziękował: 1110
Może z 5-10 FPS mi spadło, ale to i tak nic, modzik fajny i polecam Smile
[align/]Image
14/12/2013 04:47 PM
  [ETS2] Red Expert Mod v 2.6 Michal_Z_gno 3 4,278 14/08/2014 03:18 PM
Ostatni post: .:Seba11:.
  [ETS2] RED Expert Mod v 2.0 Michal_Z_gno 1 2,547 05/10/2013 11:49 PM
Ostatni post: CzesieK_BS
