Wątek zamknięty
Fael Environment v 2.2
Liczba postów: 15,103
Reputacja: 640
Podziękował: 34124
Podziękowano mu 15569 raz(y)
Jest to mod poprawiający grafikę w ETS2
Cytat:Worked on the textures of the environment, such as ground, trees, grass, road, water and so on. It DOES NOT change the weather. If you would like to use some weather mod as Improved Weather or Realistic Lighting with it, go ahead if you will, it won’t cause any conflict. My Mod does not change the Flares in the game as well, so you can use any Flare Mod available out there.
I’ve made some huge modifications on some texture and colors of the environment, such as trees, grass, water and so on.
The only thing I couldn’t manage to make it worth it in just one single file, it was the Road Textures, so I decided to make 3 versions of it, and you guys can download the one you think is better.
Version 2.2
– New Road Textures (I mixed them up and created new ones, as requested by you guys)
– Some modifications on environment colors in general
Tested on version 1.16
Author: rafaelbc
Info:
Autor: rafaelbc
Wersja gry: Testowano na 1.16.x
Notatka od Bozo, 11/04/2021 07:59 PM:
Dubel tematu = kosz.
23/02/2015 06:34 PM
Wątek zamknięty
  FAEL ENVIRONMENT v2.8 Mietek 13 7,132 27/07/2017 10:48 AM
Ostatni post: Negan44
