New Volvo FH 2013 Standalone
Rene-GAD Offline
Forumowy GAD
Liczba postów: 2,535
Reputacja: 144
Podziękował: 3201
Podziękowano mu 3447 raz(y)
Cytat:New Volvo FH 2013 Standalone
Features:
New chassis variants
4x2B (lowered)
6x2C (lowered - non-liftable)
8x4A
8x4B
6x2 with lifted axle (mid and rear)
6x2 Tandem (compatible* with Flemming V's tandem trailers) with accessories:
Coolbox
Cistern (chrome and paint)
Tipper (empty or full)
Timber frame (empty or full)
6x4 M - fifth wheel moved a bit back
All chassis versions support adding side skirts and exhausts.
The default truck, in 4x2, 6x2, 6x4 and 8x4A variants, comes without any rear wheel arches (fenders) - these are now optional accessory, in plastic or painted versions.
Reworked cabin to accept glass panel on the side (dark tint and clear).
Reworked frames and suspensions.
Reworked headlights.
Improved reflection of projectors for FH.
Added black background for FH16.
Several variants, including high and low beam, in the lower bumper projectors.
Yellow glass fog lights.
Protective mesh for headlights.
Reworked taillights - LED's for parking light
Engine lower and upper grids in plastic, paint and mirror - chrome finish, available as an option.
Painted wipers' base.
Painted panel above windshield (forehead).
Dirt deflectors (AeroKit) available as optional accessory.
New type of projectors available on the forehead.
Added LKW-Schilds (L, G, V, TIR signs) on the upper engine grid
Added accessory group to lower engine grid (you can add small lights, to various locations, including turn signals).
Added accessory group STRIPE, to enable the addition of stripes (separated from vanilla stripes) with slots for under chassis neons)
Added custom decal on the forehead (you can change it by editing decals_ohaha.dds)
Added accessory group to the back of Globetrotter cabins, with various safety signs and speed limits (50, 70, 80, 90 etc.) and allowing the addition or removal of spoilers, aerodynamic hoods and painted variant of air intake duct, for all cabin versions.
Added accessory group to the rim of the Globetrotter XL cabin, enabling you to add custom lights.
Added accessory group to the back of Globetrotter cabins, for three types of custom lights (park, brake, reverse).
Custom mirrors with markers to add small lights, including turn signals.
Stone guards.
A few custom paint-jobs.
A few custom vertical exhaust pipes.
Rear fenders / mudflaps as accessories in truck shop.
Ability to add custom rear bumpers.
Bonus: Paint-job DLC's skins available - separate mod at the same link. (credits go to Kilonum, for the latest update).
High-bar roof grills for Globetrotter cabins (w/ or w/o light box).
Roof bar for Sleeper cabin (a rework of a default SCS beacon).
Auxiliary fuel tanks available as option, for 8x4 chassis (only visual - same overall fuel capacity).
New accessories (side windows wind deflectors, painted and extended stock sun-shield, painted side and front mirrors).
Windshield and side windows decals.
Front and rear mud flaps, in three color combinations.
Custom taillights (round, square, rectangular), for custom bumpers.
Engines based on real Volvo range.
Hazardous materials transport signs for front upper engine grid.
Crane covers and crane accessory (Palfinger inspired) for 8x4a chassis.
Front bumper spoiler with high beam projectors.
Starting with
12.5s - the front engine grids are disconnected from the engine type. You can switch them in truck shop. Just look for a marker called C_EQUIP.
13.1s - the default brushed metal finish is also available (thank thebigbadonion)
17.4s - the grids are actual 3D meshes.
18.4s - you can also find an additional mod with two trailers for the tandem variant (timber and tipper).
Known issues
choosing the glass panel on the sides of the cab and windshield decals does not change the interior (if you want to see that, there is a separate, custom interior mod, in the same place)
some of the accessories might produce a visible collision with other parts. it's up to the user to choose their correct combination
you should always visit the Truck Shop and switch to the 4x2 chassis, then remove all custom accessories, before enabling a new version of the mod. After this, simply go back and install them again.
using the tandem trailers additional mod will add these to your economy! be careful when taking Quick Jobs, to avoid having them attached to an incompatible chassis truck!
Credits:
truck SCS Software
tweaks, additions and rebuilt parts ohaha
tandem variant based on Flemming V's mods.
DLC skins pack update by Kilonum
Notes:
Wheels not included. Lights not included.
This is a standalone version.
For the DLC skin mod to work, you must have the original DLC skin packs already installed and activated! The mod simply enables them, in your truck service.
Do not re-upload. Always share using the provided link.
26/11/2015 06:11 PM
piotrass Offline
Liczba postów: 96
Reputacja: 3
Podziękował: 18
Podziękowano mu 20 raz(y)
RE: New Volvo FH 2013 Standalone
Nie znam sie na truckach, moglby ktos podpowiedziec ktore pliki trzeba sciagnac? Tongue Mod posiada naczepy, czy jest to osobny plik? Tongue
Image[/url]Goście nie widzą linków. Zarejestruj się aby zobaczyć ukrytą treść.
27/11/2015 12:24 AM
MAD MAX Offline
F U R Y - R O A D
Liczba postów: 4,178
Reputacja: 195
Podziękował: 2204
Podziękowano mu 2840 raz(y)
Jeżeli w paczce masz auto i naczepę to zawszę po wypakowaniu będziesz miał dwa pliki scs najczęściej mają nazwy, auto to będzie marka i model a naczepa będzie miała trailer.....
Wykrzyknik Wykrzyknik
27/11/2015 12:35 AM
Rene-GAD Offline
Forumowy GAD
Reputacja: 144
Podziękował: 3201
Ściagnij wszystko co tam jest ponieważ to są też dodatki do tego trucka - orurowania, naklejki na szyby itp... również siatka.
27/11/2015 01:16 AM
 Podziękowań: MAD MAX , .:KoxTrucker:.
  Volvo FH 2013 Darson 0 2,818 12/03/2017 07:15 PM
Ostatni post: Darson
  [ETS2] Volvo FH 2013 Ohaha v 21.13s Michal_Z_gno 5 4,811 15/10/2016 01:28 PM
Ostatni post: Michal_Z_gno
  [ETS2] Volvo FH 2013 v20.14s Michal_Z_gno 0 1,774 22/07/2016 11:37 AM
  Volvo FH540 2013 v4.2 [1.19.x - 1.22.x] Marek_30 0 2,078 27/01/2016 10:49 PM
Ostatni post: Marek_30
  Volvo FH 2013 Zwierzak 0 2,069 13/01/2016 01:07 PM
Ostatni post: Zwierzak
